raiko12345 Posted June 1, 2017 Share Posted June 1, 2017 Hi I bought a Pod Pro and i opened it up and there was 1,2v chip in it. I also have POD 2.0 with 2.3v chip inside, so it thought i will try to switch chips, and it didnt work, only two lights on the left and on the right where are theres holes like vents lighted up. And now when i put my originaal 1.2v chip back into POD Pro, same thing happes, only lights and the pod wont power up and the chip heats up really good. I there a chance that when 2.3v chip is applied, the pods brain goes grazy or something? no i need to reset te battery inside, or firmware? Thanks Raiko Quote Link to comment Share on other sites More sharing options...
sghost666 Posted June 1, 2017 Share Posted June 1, 2017 Was the POD Pro working fine until you tried to swap the chips? Quote Link to comment Share on other sites More sharing options...
raiko12345 Posted June 1, 2017 Author Share Posted June 1, 2017 Yes it was working. If ill try to reinstal firmware with midi to usb cable will it work? Quote Link to comment Share on other sites More sharing options...
raiko12345 Posted June 1, 2017 Author Share Posted June 1, 2017 POD 2.0 is working fine when i put back 2.3v chip Quote Link to comment Share on other sites More sharing options...
sghost666 Posted June 1, 2017 Share Posted June 1, 2017 Yes it was working. If ill try to reinstal firmware with midi to usb cable will it work? No, the POD Pro can handle patch edits via MIDI SysEx, but firmware has to be a physical EPROM swap (meaning it is on a hardware chip that the POD Pro itself cannot program). The firmware between the two units isn't compatible at all. Quote Link to comment Share on other sites More sharing options...
raiko12345 Posted June 5, 2017 Author Share Posted June 5, 2017 I got mine working by taking the chip out and turning it on for few seconds and then ja placed chip back and it worked. This can be helpful for some others with freeze problems i saw. Quote Link to comment Share on other sites More sharing options...
