Stanimal72 Posted June 6, 2017 Share Posted June 6, 2017 I am having a problem connecting my POD HD500x to my PC. I have installed the latest drivers and have tested usb port with known working devices but every time I connect my HD500x I get Unknown Device error message. Please help. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 6, 2017 Share Posted June 6, 2017 Try cycling the power in both the POD and the PC. Also try using different usb ports, especially the rear panel ports. Quote Link to comment Share on other sites More sharing options...
Stanimal72 Posted June 6, 2017 Author Share Posted June 6, 2017 Thanks for the rapid reply. I have cycled power on both units and tried every USB port available. Still nothing. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 6, 2017 Share Posted June 6, 2017 I suggest you open a support ticket. There may be some hardware or driver conflict issues. http://line6.com/support/tickets/add.html Quote Link to comment Share on other sites More sharing options...
bjnette Posted June 7, 2017 Share Posted June 7, 2017 Were the latest drivers installed under Win 10? I presume you are trying to get it recognized as an Interface? And that it was working before Win 10? Have you been able to make it work in EDIT.? I might suggest that you check you have the latest of everything in software including Monkey and EDIT and download those and the drivers. Another point will be the Flashware in the HD. If it is older it might need older version of the software then once updated enough the latest then works! GOOD LUCK Quote Link to comment Share on other sites More sharing options...
Chicko_17 Posted February 22, 2021 Share Posted February 22, 2021 I had this thing working with Line 6 podhd500x edit on my laptop (Acer Aspire Ryzen 3), but it doesn't work on my pc. they're both on windows 10. Has the issue been resolved already? Quote Link to comment Share on other sites More sharing options...
