twpmeister Posted June 6, 2017 Share Posted June 6, 2017 Doable or am I out of luck? I'd like to use real preamp with fx from helix for some patches and modelled preamp for others. I know this is possible with regular serial loops but how could I make it work with Parallel? Right now I'm simply going straight into the fx return for all modelled pres but I do like the original amp also (lionheart) and its a shame not to use it. I'm thinking a 3 cable method might be my best compromise - Guitar-helix Send-Front of amp 1/4 out-fx return. Route patches to send only when I want my amp and 1/4 only when I want models. Downside with this is all fx will have to be before my amp for those patches. Is this my best solution or can someone more knowledgeable offer any insight? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
shredzilla1964 Posted June 7, 2017 Share Posted June 7, 2017 I do 4cm with a jvm 410h... It has a parallel Loop that has a mix adjustment that allows you to make it serial, works great! Quote Link to comment Share on other sites More sharing options...
twpmeister Posted June 7, 2017 Author Share Posted June 7, 2017 I do 4cm with a jvm 410h... It has a parallel Loop that has a mix adjustment that allows you to make it serial, works great! Unfortunately no mix on mine, it is what it is. Thanks anyway Quote Link to comment Share on other sites More sharing options...
