wrappedinchains Posted September 23, 2013 Share Posted September 23, 2013 I browsed through all of the threads and didn't see a similar scenario that matches the symtoms I am facing with my Vetta II that I just purchase yesterday from Guitar Center. While playing on the amp and modifying the preexisting patches for a tone to my likeing the sound coming out of the cab cut off abruptly and the screen froze on channel 1A. I turned the amp off and waited about 30 seconds and turned it back on. Now both of the screens are completly blank and no sound is coming out. I tried to run the flash update, but that didn't seem to work. I left the amp off for several hours and tried again and both of the screens are completly blank still and no sound is coming out of the cab. Quote Link to comment Share on other sites More sharing options...
sliding_billy Posted September 24, 2013 Share Posted September 24, 2013 When you ran the flash, was Monkey able to detect the amp properly? Also, what midi device did you use to flash? Quote Link to comment Share on other sites More sharing options...
wrappedinchains Posted September 24, 2013 Author Share Posted September 24, 2013 I just used a midi to usb cable and connected through Monkey, but Monkey never actually saw the device. I don't think the flash actually installed anyway because none of the prompts actually came up on the amps screen when I followed the instructions on monkey. It seems like the cpu in the amp is "stuck on stupid" so to speak. The error occured when I switched from one of the factory presets that was a a relatively normal volume level to an adjacent preset that was at extreme loud for some odd reason. I'm about to just return the amp to guitar center I suppose, I played on it for all of about 15 minutes before it went haywire. I can't have this happen live. Quote Link to comment Share on other sites More sharing options...
sliding_billy Posted September 25, 2013 Share Posted September 25, 2013 The only usb midi device that works consistently is the midisport uno. Assuming you do not have one to try, I think that returning the amp while you still can is your best course of action. Quote Link to comment Share on other sites More sharing options...
wrappedinchains Posted September 25, 2013 Author Share Posted September 25, 2013 The midi device really has nothing to do with the error that occured with this thing. I am thinking that the previous owner of this amp knew it was jacked up thats why he traded it into Guitar Center in the first place. Quote Link to comment Share on other sites More sharing options...
sliding_billy Posted September 26, 2013 Share Posted September 26, 2013 Not referring to the error but the ability to even attempt a flash. Quote Link to comment Share on other sites More sharing options...
DickFoster Posted September 30, 2013 Share Posted September 30, 2013 The midi device really has nothing to do with the error that occured with this thing. I am thinking that the previous owner of this amp knew it was jacked up thats why he traded it into Guitar Center in the first place. What he is suggesting is that you use the MIDI port to reinstall the software. Before you do it's best to make sure the battery inside is good. That seems to be one of the major sources of problems. The battery dies then the RAM gets all screwed up and the amp doesn't know what to do or how to work right. Replacing the battery and reloading the software fixes a lot of what ails these amps. Unfortunately the battery is inside and involves a little soldering to replace. Once the battery has been replaced, it's good to go for five years or so before needing another new one. Quote Link to comment Share on other sites More sharing options...
kevinm213 Posted December 23, 2014 Share Posted December 23, 2014 This is exactly what happened to me! The battery wasn't good inside when I went to reinstall the software. It screwed my amp up and left the banks blank. I took it to a reputable tech from Sam Ash and he replaced the soldered battery & made it replacable- snap it/snap out, for future incidents. However, all my banks are still blank! I tried reinstalling with Monkey basically blind folded at this point but to no avail. Any help here from you techs would be greatly appreciated. While some of you guys purchased used for about $450 on this amp, I bought my, Vetta II Combo, brand new for $1775 before taxes. My feeling on this was that Line-6 put out an update that was bad, and everyone that tried it lost the use of their Vetta's. PLEASE HELP! Quote Link to comment Share on other sites More sharing options...
NapalmSprings Posted March 28, 2025 Share Posted March 28, 2025 I have the same issue i just had mine fully restored because it blew the power supply the memory battery and multiple caps and resistors love the way this thing sounds i really want it to work but it sits on a blank preset and doesnt want to change from that screen even when turning off or connecting the fbv longboard no buttons work!!!! Again i miss the way this thing ripps but just so many problems!!!! Quote Link to comment Share on other sites More sharing options...
