JLondon Posted July 15, 2017 Share Posted July 15, 2017 Haven't used "Pitch Wham" in a while but never had a problem in the past. So I'm trying to set up for a Gilmour "Marooned" type sound. I can't figure out how to stop the effect from sounding out the steps between the notes as it goes up and down the scale - like running your finger up piano keys. Never experience this before and I can't find anything in the settings menus that seem to have anything to do with it. I've got mix at %100, heal and toe position set 0 - 12 assigned to expression 2, and "position" at 0. How do I get a smooth slide transition between the notes? I apologize in advance if this has been covered a billion times, but my attempt at a search failed to produce anything. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted July 17, 2017 Share Posted July 17, 2017 Haven't used "Pitch Wham" in a while but never had a problem in the past. So I'm trying to set up for a Gilmour "Marooned" type sound. I can't figure out how to stop the effect from sounding out the steps between the notes as it goes up and down the scale - like running your finger up piano keys. Never experience this before and I can't find anything in the settings menus that seem to have anything to do with it. I've got mix at %100, heal and toe position set 0 - 12 assigned to expression 2, and "position" at 0. How do I get a smooth slide transition between the notes? I apologize in advance if this has been covered a billion times, but my attempt at a search failed to produce anything. I use pitch wham quite a bit, and do not experience that. What firmware revision are you running? Quote Link to comment Share on other sites More sharing options...
