ahfhahtl Posted July 20, 2017 Share Posted July 20, 2017 Hello! I am a helix LT userThere is a problem with me.I can not use the looperLooper Start button is not pressedI do not respond when I press the Looper Start buttonAs shown in the pictureWhen you try to use a looperPress MODE to EXIT Looper This picture is a basic preset, and the same is true for a preset created by me Please help me Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted July 20, 2017 Share Posted July 20, 2017 After entering Looper footswitch mode, you must first record a loop. Record/Overdub is FS8 (second switch from the left on the bottom row). Quote Link to comment Share on other sites More sharing options...
danny1m Posted August 24, 2017 Share Posted August 24, 2017 got the same issue did you find a fix mine was working till i stasredmessing with snapshot now won't work Quote Link to comment Share on other sites More sharing options...
JeffWadey Posted May 18, 2020 Share Posted May 18, 2020 I have the same problem.... i am new to Helix. i can't hear the loop playing back. i'm pretty sure i have set it up correctly.... is there something i am missing? Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 18, 2020 Share Posted May 18, 2020 2 hours ago, JeffWadey said: I have the same problem.... i am new to Helix. i can't hear the loop playing back. i'm pretty sure i have set it up correctly.... is there something i am missing? Hi Jeff, May be helpful to take 10 minutes to look at this old video that covers the basics of the Helix Looper functions. Should be enough to get you rolling. Check it out. Quote Link to comment Share on other sites More sharing options...
JeffWadey Posted May 18, 2020 Share Posted May 18, 2020 37 minutes ago, datacommando said: Hi Jeff, May be helpful to take 10 minutes to look at this old video that covers the basics of the Helix Looper functions. Should be enough to get you rolling. Check it out. thanks for the help... i have actually watched this video and followed the steps... still no sound when i record a loop.... i am wondering if i've done something dumb with the way i have the settings ? or the way the Helix is set up.... i have used looper pedals before.... who knows.... it's prob something obvious i am missing. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 18, 2020 Share Posted May 18, 2020 1 hour ago, JeffWadey said: still no sound when i record a loop.... Well that's really odd. Can you hear the looper from the headphone out socket. Yes/No. If - Yes - and you are also getting audio to your monitors/amp/FRFR Cab from the Helix using a regular/normal preset, then you should be able to hear the looper. If - No - The looper section of the Helix is just like any other amp or effect and if they are all functioning as they should then it's time to raise a ticket with Customer Support. Quote Link to comment Share on other sites More sharing options...
