EVH 5150 III 50 Watt Head - Channel Switching & FX Loop On/Off with one FS in Command Center?
JC-Tonequest
Can you assign more than one parameter control to the footswitches in command center? I just picked up an EVH 5150 III 50 Watt head. It has midi control to change the channels on the amp via Midi PC, and turn the FX Loop on/off via Midi CC's. I'd like to be able to have the same footswitch control the amp channel and the FX loop state. Thanks in advance.
From Helix Manual:
"NOTE: Each footswitch can have up to 8 assignments. If you attempt to add a ninth,
"Can't assign any more blocks to this footswitch!" appears in the header:
Can’t assign any more blocks to this footswitch!
Thanks for the reply. I do realize that you can assign up to 8 parameters to the footswitches. I was referring to assigning the functions I previously stated in the command center menu alone. Have one footswitch control the cannel and loop on/off state simultaneously in the command center.
