line 6 g-10
jsierz
 Because of the wiring in some acoustic guitars a 1/4" female to 1/4" male adapter is required to get them to work with the g10 transmitter.
As for your stomp boxes, if I understand correctly you are trying to go: Guitar>G10 system>stomp boxes>amplifier?
You should provide a little more detail about the working and non-working configurations. I can't really tell what the G10 transmitter is plugged into, or what the base station is plugged into. And when you say "won't work". What exactly does that mean? Does the green light on the transmitter come on? What's the color of the light on the receiver base?
I can't seem to use my g-10 unless it's plugged into my amp with doesn't have an effects loop
won't work plugged into my stomp box chain
also will not work plugged into my acoustic guitar
I think a little further explanation of each of these three items would be helpful. Also helpful information would be which particular electric and acoustic guitars you are using.
