joel_brown 357
You have to manually turn off the cab - even when using the Pre Amp only models. Then the mic settings doesn't do anything. Otherwise it will use a cab Impulse Response (IR) and that will change you're tone quite a bit.
keggers 0
Thanks Joel, I have gone in and done that since posting but not tried it yet, will be setting the complete rig up this afternoon
pfsmith0 226
I like to think of the Pre versions of the amps as just another color palette to choose from. Full amp or Preamp. Both with or without cab/mic. You can see freq responses and distortion levels here.
If you select pre amp only on hfx edit it automatically throws up cab and mic settings, are they just there as a matter of course and have no function or do they function, I thought that the idea of pre amp only was to take those details out of the equation
