jimbob0898 Posted September 13, 2017 Share Posted September 13, 2017 I am pretty certain this is not possible but thought I would ask. Is it possible for the Helix to send a tap tempo signal out, via the CV I assume, to a pedal that has a tap tempo in 1/4" socket like the new TC Flashback 2? I could just get a bog standard footswtch to do it but would rather use the Helix if possible. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted September 13, 2017 Share Posted September 13, 2017 CV, I am pretty sure no.But MIDI sync is now possible. out or in. Quote Link to comment Share on other sites More sharing options...
jimbob0898 Posted September 13, 2017 Author Share Posted September 13, 2017 Thanks for the reply Peter, yes that is what I thought, worth asking in case I was the wrong though :) Quote Link to comment Share on other sites More sharing options...
jimbob0898 Posted January 8, 2018 Author Share Posted January 8, 2018 I finally figured how to achieve this today with the help of an Arduino. In the command centre I set the tap switch to CV toggle, then used that signal to an Arduino which I programmed to do a pulse with each toggle, then sent that to an analogue switch IC which replicates the tap footswitch and sends the signal on to the Flashback. Happy days, also the analogue switch IC has three more outs so I can do it to other pedals as well if needed. Quote Link to comment Share on other sites More sharing options...
Cyrilito Posted February 23, 2018 Share Posted February 23, 2018 Hello guys!I have a question and am not sure if you answered it yet.I want my Helix tap tempo to be controled by an external tap tempo coming from an other tap tempo's delay pedal. The aime is that my tap tampo, from the helix, will change with the tap tempo of the external pedal. And the connection is through a jack gettin out of the external pedal.Any ideas? I didn't find any solutions yet.Thank you guys! You would help me so much here^^See ya!Cyril Quote Link to comment Share on other sites More sharing options...
mkornell Posted February 24, 2018 Share Posted February 24, 2018 Can't do it the way I think you want to do it. The only way to set the Helix's tempo is via MIDI. You can either slave the Helix's MIDI clock to an external MIDI clock source (or v/v - use the Helix as the master) or send CC#64 "tap" messages to the Helix. Quote Link to comment Share on other sites More sharing options...
