SirNickDone Posted September 29, 2013 Share Posted September 29, 2013 Hi everyone, I can't go to the setup page as indicated in the manual: I press and hold the TAP footswitch (and the m5 goes to the tuner) and then press the MODEL SELECT button but nothing happens, it only goes to the normal effect screen where i was... What am I doing wrong?Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 29, 2013 Share Posted September 29, 2013 The manual says: To access the setup pages, press and hold the TAP footswitch then pressthe MODEL SELECT knob. ... hold (don't release) the TAP switch while pressing Model Select....... Quote Link to comment Share on other sites More sharing options...
SirNickDone Posted September 29, 2013 Author Share Posted September 29, 2013 You're right! Thank you! :) Quote Link to comment Share on other sites More sharing options...
mwollaston Posted March 19, 2020 Share Posted March 19, 2020 I have a related problem. When I switch on my M5 Stompbox, I am unable to change from one 'Model' to another, using the Model Select button.... it just stay on the same model. I figured it might be worth doing a factory reset, but I would have to go through the steps described above, and I can't do that because the 'Model Select' button doesn't work! It's probably a hardware (button) fault, in which the factory reset is unlikely to work, but I thought it was worth a try. Has anyone else suffered from a non-working 'Model Select' button? Quote Link to comment Share on other sites More sharing options...
