rising_sun5 Posted September 25, 2017 Share Posted September 25, 2017 Hi! Please can someone help me with setup. I would like to plug my guitar in Firehawk FX and get two output sounds ( at the same time - in real time): 1. one totaly clean guitar sound without any effects ( "dry" - unaltered sound ) that can record with my PC through mixing console while playing ( for reamping later ) 2. second sound with all effects and amp models ( "wet" sound ) that goes to my amp that i can record sound with all effects ( to amps return in fx loop ) What would be the best way to connect cables from Firehawk FX to amp and to mixing console and how to setup position of FX loop in Firehawk REMOTE APP. Thank you! :-) Mark Quote Link to comment Share on other sites More sharing options...
suedehead99 Posted September 27, 2017 Share Posted September 27, 2017 Hi, I don't think you can do what you want with the FHFX. For dual signal paths you would need the HD500X or the Helix. Maybe you could use the fx loop to send mono out then split it to go to your console and the other back to the mono return to then have the effects added to go out to your amp. I don't know, just thinking aloud. Quote Link to comment Share on other sites More sharing options...
rising_sun5 Posted September 27, 2017 Author Share Posted September 27, 2017 Thank you for reply! Sounds interesting! :-) I will try also use ABY pedal, so I can split original guitar sound to 2 outputs to get two sounds at the same time. One cable from ABY goes to FIREHAWK FX input and then to amp with all effects, and other to mixing console for record clean sound for reamping later. Quote Link to comment Share on other sites More sharing options...
firehawkkwah Posted July 21, 2020 Share Posted July 21, 2020 Am interested in doing this, too. Thought I could just record the output straight from the guitar, but came across this: most electric guitars have passive pickups, so splitting the guitar signal right after the guitar is fraught with danger. If the split isn’t done with an active/buffered splitter (instead of a simple “Y” cable) an impedance mismatch happens, and the guitar pickups are loaded incorrectly. An improperly loaded guitar both sounds and feels terrible, so it should be avoided at all costs. Anyone tried the FX loop out-split trick? I have not, but if it works then I'm game. Or, any other way to reamp stuff with FHFX? Quote Link to comment Share on other sites More sharing options...
mra68 Posted April 30, 2021 Share Posted April 30, 2021 Hi I am interested in this also, how did you get on? I was thinking if i cant split through fx I may have to use a di box, one cable going to fx other going directly to interface to get both signals. Would you use active of passive di box? Quote Link to comment Share on other sites More sharing options...
