dep825 Posted November 3, 2017 Share Posted November 3, 2017 Brand new JTV 69SSS just received....flashed the memory and installed all the latest drivers when I received it...then got pulled away for a week...just got back to it: 1) Using Alt tuning dial, all tunings work fine EXCEPT the drop 1/2 step and drop whole step tunings. They went totally discordant. 2) Also, the volume output was about 50% of what it was originally. 3) The "modelling" knob does not activate/light up when the knob is pushed down...takes multiple pushes...or I turn and push and maybe it works.... or I hold down and maybe it works...but if I hold too long and, I get into customization mode....and I cannot get it out of customization mode. And I can't turn modeling off with just a single push or even a double push. It takes real wrestling with the knob to turn off modelling. I tried to reach Line 6 but they say they are out for lunch - for the past 4 hours!! I flashed the memory...that fixed the issues in item 1 & 2 until I turned the guitar off and then back on...then the same issues returned. Nothing has fixed item #2. So: a) Is a JTV guitar so finicky that the volume and/or drop tunings will work or not at their discretion?, and b) How in the world is the modeling knob supposed to work...aren't you supposed to be able to turn it on/off with a single push? Or is mine defective, or c) Is this whole guitar defective? Thanks Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 3, 2017 Share Posted November 3, 2017 Log a support ticket. Definitely sounds odd that it would do it that way. I might have to have a look at it. We had a day where there were a couple of meetings going on. Quote Link to comment Share on other sites More sharing options...
dep825 Posted November 4, 2017 Author Share Posted November 4, 2017 Thanks for reply.... After some struggling and after helpful thoughts from Kody....some progress.... 1) Modelling button was "bottoming out"...stuffed interior of knob with bit of scotch tape...FIXED! 2) Volume issue seems to have fixed with the 4th patch cord....but have not yet ruled out defective (or poor contact) on interior of 1/4" port (eg why do the patch cords all work on my other guitars and not the JTV-69 - am still testing). 2) I think the alt tuning issue may be caused by inaccurate intonation....especially on the higher strings...those are the ones that really get discordant and seem to have a double tone to them...will try to intonate myself....leaping into the deep water!! Wish me luck....Will advise.... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 6, 2017 Share Posted November 6, 2017 If the intonation was off, it would generate a whistling howling sort of sound. With Alt Tune capabilities, intonation is even more crucial, an precision tuner such as a Peterson is necessary. And should not be intonated while in Model mode. There is also "dual tone effect" to consider,... hearing the standard tuned pitch off the string and thru the Alt Tune pitch thru the amp, at the same time. If the Alt Tune warbles, it may also be a problem with the pick-up height distance between the pick-up and the strings. Higher strings (G, B, Hi-E) typically do not need intonation adjustments as much as the lower strings do. It's a string physics thing discussed in a number of guitar repair books and magazine articles. First need to determine what part of the set-up needs adjusting. Each part of the set-up is interdependent on the others. It isn't just one solution for everything. Quote Link to comment Share on other sites More sharing options...
dep825 Posted November 7, 2017 Author Share Posted November 7, 2017 Kody from Line 6 was very helpful in explaining my issue - thought I'd post this for any others that might encounter it: I was hearing dissonance when using the lowered alt tunings - and ONLY the lowered tunings (eg down 1/2 step or whole step): The issue arises when using lowered tunings and the amp is not loud enough to overpower the acoustic audio from the string(s). The ear hears acoustic audio from the string(s) - the E string playing E - while thru the amp in the alt tuning it is playing E flat (1/2 step down) or D (full step down)...the ear can hear both the acoustic not (E) and the note thru the amp (E flat)...this makes it sound as if the strings are dissonant. But they are not. And, the issue only occurs when playing any flatted or sharped tuning. Various fixes/tests are: 1) Turn the amp louder so it overpowers the acoustic audio from the actual string; or 2) Listen to the amp thru head phones (which should cut out the acoustic audio from the actual string) and only the amp sound will come thru the headphones, or 3) Use a tuner to check the notes from the amp (so it must be close or directly plugged into the amp) so the tuner will show the note being played thru the amp - not the acoustic audio note. In all cases, the note from the amp should/will show 1/2 or whole step down - which is correct. The dissonance is caused by the acoustic sound the actual string is making. This has nothing to do with any resonance from the strings between the nut and the pegs....altho, other posts in the forums suggest it doesn't hurt to dampen that area. Hope this helps. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 7, 2017 Share Posted November 7, 2017 Yeah, it's that "dual tone effect" I mentioned earlier. Kody and I listened to the sound clip. Good recording job, made it easy for us to figure out. Thanks. Quote Link to comment Share on other sites More sharing options...
