Maniek1991 Posted November 14, 2017 Share Posted November 14, 2017 Hi!I am using my new Helix LT for few days and it is time to start to use it for what I bought it for. I have some problems with configuration.I need to configure it this way:Signal with effects - 1/4'' - this is working fineClean signal (straight from guitar) - USB - as FIRST channelSignal with effects - USB - as SECOND channelI have problem to send sound from Helix to computer - both cases. My computer see it correctly - I can hear sound from PC in monitors connected to 1/4'' and my computer see Helix also as recording device, but it do not get any sound (checked in control panel - recording devices - Helix).How I confugured Helix - I know that now it should send only clean signal, so it is not really what I want to get, but my computer do not get any signal and I can not firure out what is wrong :(https://imgur.com/a/OX9hY Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted November 15, 2017 Share Posted November 15, 2017 Most likely it's a configuration issue with your recording software. Very often they have their own configuration separate from the basic configuration of the computer in order to work with the ASIO driver which isn't used in the basic computer configuration. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted November 15, 2017 Share Posted November 15, 2017 Are you using a DAW software on your PC? Quote Link to comment Share on other sites More sharing options...
Maniek1991 Posted November 15, 2017 Author Share Posted November 15, 2017 I have DAW installed (Studio One), but I do not use it at the moment.I checked it with all programs I have on my PC that came to my mind - Audacity, Rocksmith, OBS Studio. All of them do not get any signal.So I think it is more about drivers or bad configuration of my Helix. Quote Link to comment Share on other sites More sharing options...
aleclee Posted November 16, 2017 Share Posted November 16, 2017 Clean signal (straight from guitar) - USB - as FIRST channel Signal with effects - USB - as SECOND channel Any particular reason you can't got with the usual Channel 7 for dry guitar? Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted November 16, 2017 Share Posted November 16, 2017 OK, so... To do what you want to do, just build your patch the way you normally would for use with speakers, don't worry about leaving a "dry" path for the clean guitar. In your DAW settings, make sure that Helix Inputs 1-8 are available (some settings automatically set it to only having 1-2 available). Make sure your speakers/monitors are connected to the Helix outputs (1/4" or XLR doesn't really matter) Set your track that you want to record the EFFECTED (amps/cabs/FX) signal to record on USB 1 or USB 1/2 for stereo. Set the track that you want the DRY guitar to be recorded on to USB 7. No when you arm both of these tracks the first one will be the "full" signal with everything on it and the second track will be JUST the guitar directly from the input on Helix. I know it seems silly, but I've seen a few people out there trying to monitor through the speakers that are already hooked up to their computer. To use the Helix as a USB interface, you have to hook you monitors up to the Helix. No condescension intended, just trouble-shooting. Quote Link to comment Share on other sites More sharing options...
