Sign in to follow this
geroin
Hardware Monitor Level for Spider V
Will "Hardware Monitor Level" setting be ever supported by Spider V ? It was extremely handy to turn "hardware" sound off while using DAW for POD HD 500. Right now I'm unable to turn the cab off on Spider and use IRs in DAW instead.
You can turn all modeling off in Spider V. The effects will have to be turned off manually in the app or on the app. To turn of amp modeling, using the Spider Remote app: select your amp then tap the icon to change out the amp, select from the "Clean" amp category, the first option is "No Amp". To do this on Spider V, press AMP then EDIT. Push the rotary/push knob to change out the amp model, then scroll to the very first option which will be "No Amp".
That won't help. If I turn all modeling off, the output will still be the mix of DAW output and "dry" guitar signal, while I need just DAW output. Also, I still want Spider to emulate the amp and effects, but use DAW for emulating cab + mic using IRs.
Ah sorry, I misunderstood the question. When I've recorded with Spider V I turn off the monitoring for the guitar track I am recording in my DAW. That way I'm hearing the guitar sound of Spider V, which is being recorded, plus the playback of any other tracks, though I don't think this won't help if you're trying to use IR's.
You could use Spider V for just amp/effects, and use an IR in your DAW for cab/mic modeling. To turn the cabinet off you can change out the cab to the "No Cabinet" option in the Spider Remote app, or on the amp itself push AMP followed by EDIT, scroll down to the "Cab Enable" option, click on the rotary push knob to toggle between on and off. I haven't yet tried recording Spider V with any IRs yet, but I'm going to have to give it a go.
