tuner calibration
redarmy82
I don't believe you can calibrate the tuner. If you need the tuner to tune and it allegedly doesn't work, how do you know you're out?  =:-)  (Sorry, I couldn't resist)
I sometimes tune using harmonics. For example, on the low E play the harmonic at the 5th fret and then on the A, the harmonic at the 7th fret. Listen for vibrations. When the 2 notes stop vibrating, they're in tune.
  • 1 month later...
From a Google search:  Q: How do I perform a factory reset on the Spider V series? A: Hold down the Home button to access the settings menu. Scroll down with the encoder to where it says Factory Reset. Scroll to the right and press the encoder knob to hit Yes.
Thank you!
