georgegav Posted December 29, 2017 Share Posted December 29, 2017 So I recently got a UX1. I want to record both instrument and vocal at the same time on separate channels. I've set the inputs so both are coming in on POD farm, and in POD farm there is a REC tone A and REC tone B, meaning both can recorded separately. However, when I use software to record it only pics up the first output, and not the second. I can use REC A&B to record both at once but I'd like to record each on a separate channel. Is there a way of doing this.Apologies if it's not too clear, I'm new to technical gear. Until now I've been recording with a zoom mic and editing in sony Vegas. I've attached a screenshot of my setup on POD farm. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted December 29, 2017 Share Posted December 29, 2017 You will have to do the rest in whatever DAW you are using to record. What do you currently use to record with? Quote Link to comment Share on other sites More sharing options...
