HX Effects Bypass programmable?
k-grimm403
So I see that the HX effects can be set to bypass mode by holding the tap/mode button at the same time. I purchased one and am excited to get this hooked up to my small pedal board
My question is can you set this up to be pre-programmed on a per preset or even per snapshot level? Or is this only available as a manual function.
I'm planning on integrating this with a few different pedals with midi function(chase bliss/eventide) and was hoping when I am not using the HX effects than it would not affect the signal at all. Because I there is only 2 effects loops I unfortunately have to set this up in a chain instead of all through HX effects.
Thanks in advanced!
