gwisznia
Bluetooth headphones are allowed?
Hi, I found some articles about the impossibility of connecting Bluetooth headphones at the same time as the fx100. But they where old. I wanted to know if line 6 software solved this issue on 2018 or still need cable connection.
Thanks
Gabriel
you have to use a cable, it only accepts audio via bluetooth, but doesn't send it. (probably a good thing, as the delay, even when minimal, when using bluetooth transmission would be quite distracting when playing).
If you want to have your phone connect to bluetooth headphones at the same time as being connected to change the fx100's settings: That is possible if the phone supports it, but has nothing to do with fx100 firmware/capabilities. That is all handled in your phone.
Thanks
Gabriel
Bluetooth latency isn't a L6 problem to "solve", because it's not their technology. It's also unlikely to be solved anytime soon by whomever it is that develops Bluetooth protocols, simply because 99.97% of users are blissfully unaware that it even exists...as they're not trying to play guitar with it. For the overwhelming majority of Bluetooth applications, what little latency there is, is of no consequence.
