kritmen Posted February 6, 2018 Share Posted February 6, 2018 Hi all - Long story short, I've been running cheap, non Phantom using mic straight into the DL4 which goes OUT to a Boss VE20 which goes OUT to my PA. This was working fine until I bought a nicer Phantom Powered Shure 87a. With that signal chain I can't power the mic appropriately and when I run the chain as: Shure 87A IN to VE20 w/Phantom Power enabled OUT to DL4 OUT to PA I get some strange feedback loops/sound issues. Thoughts on what the problem could be? I know that professional artists use the pedal for vocals so it must be able to handle the Phantom Power somewhere/somehow. Having done research it looks like some people use a Behringer ULTRA-DI DI400P Passive Direct Box. If you think that may be a solution, where would this apply in the mic to pedal chain? Thanks a ton in advance for the help. I'm at the finish line with my set up and look forward to having things working right! -Kirt Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 6, 2018 Share Posted February 6, 2018 DL4 is an instrument level signal device and not designed for use with phantom power. Phantom power is meant for use with condenser mics. Quote Link to comment Share on other sites More sharing options...
