Tremelo rate controlled by expression pedal
Indianrock2020
You may be right.   So low, maybe imperceptible tremelo for most of the song but with speed set fast, then pedal in the mix or level for accent at certain points.
You could have the tremolo on all the time, then make the mix sweep from 0-100%, maybe on a parallel path.
You can configure it so that the bypass state (on/off) is controlled by the expression pedal position. I set mine up so that anything greater than 0% on the expression pedal turns the tremolo on, then you have your whole control sweep, and going back to 0% (heel-down) turns it back off.
