FBV Express MkII With Other Products?
  • 3 weeks later...
Even if the Fender would support midi input, you wouldn't be able to use it directly - you would have to connect it to a computer via USB and use the "Line 6 FBV Control" software to configure what midi-events the button presses/expression pedal should generate. And you would then need to hook up your computer's midi-out to the target amp.
So answer to "can I control other midi devices with a FBV controller" is yes and no - you need a computer as middleman.
