Sign in to follow this
geeman37
FBV3 Tuner
Hi there I have the FBV3 controller and when I tune my guitars I can' seem to see anything on the screen on the pedal that tell you when your note is flat. Is there something I'm not seeing ? Thanks in advance for any help ,
Regards,
Gary.
the FBV3 doesn't have a tuner on its own/it just displays whatever characters the amp sends it to display...
At least with the Amplifi you'll get a display like
I---- ** ----I    on pitch
I〉〉〉〉    ----I    way flat
I-〉〉〉    ----I    closer, but still flat
I--〉〉    ----I    getting there...
I---〉    ----I    almost, tiny bit flat
I----    〈---I    damn, you went to far and are now sharp
I----    〈〈〈-I    guess you're getting the idea by now :-))
when you're on pitch, and various >> or << on either side - the more brackets on the left, the further away you are from the target pitch (flat), as you approach the target, the number decreses, and if you see the ** then you hit the target, same with going sharp, the more and the further out they reach, the further away from target pitch.
Edit (since the quote seems to not like my unicode variant, here in plain ascii):
I>>>>    ----I    way flat
I->>>    ----I    closer, but still flat
I-->>    ----I    getting there...
I--->    ----I    almost, tiny bit flat
I----    <---I    damn, you went to far and are now sharp
I----    <<<-I    guess you're getting the idea by now :-))
  • Upvote 2
Create an account
Register a new account
Sign in
Sign In Now
