Parallel Routing
themetallikid
Couple questions....
1) you can only have 1 parallel routing chain per signal path A and B right?  I don't think I missed anything here, but just asking.
2)  When I had my Fractal a nice thing was putting effects in Parallel or Series.  I really liked putting my delays/verbs in separate lines out.
       2a) If I add an effect say a chorus on a parallel line, with Fractal I would adjust the mix to 100% and adjust the level to +/- the effected sound as opposed to Series - adjusting the Mix % to get the effect I wanted.  Does this hold true yet with Helix?
      2b) If I do separate my Delay/Verbs into a parallel chain...because I cannot just run the outputs to the output block (it has to connect right before at its latest point) does that defeat the purpose of running them parallel or would there not be much difference?
It's slower at work and my mind sometimes wanders and needs to know these things.
1) Yes. That's one parallel path (1b) for path 1 and one parallel path (2b) for path 2.
2a) Yes
2b) No, you can have separate outputs for paths a and b. You don't have to merge the paths before the output. Either way, it would not defeat the purpose of running them in parallel.
