jeffjones1980 Posted April 1, 2018 Share Posted April 1, 2018 Anyone using 4cm I can't find anything about how to rout the effects in front of a amp Quote Link to comment Share on other sites More sharing options...
codamedia Posted April 2, 2018 Share Posted April 2, 2018 Guitar > HX Effects Input > Setup blocks of effects that normally go in front of an amp such as comps, overdrives, etc.... Insert an LOOP Block in the HX Effects > Send that loop out to the input of your amp Effects Send from your amp to the RETURN of the loop in on the HX Effects > Setup blocks of effects that normally go in the loop of an amp such as delays, reverbs, etc... Output of the HX Effects into the effects loop RETURN on your amp. Doing that will limit your HX Effects to 8 effects, and 1 Loop Block... (9 blocks total) Hope that is what you are after. 1 Quote Link to comment Share on other sites More sharing options...
jeffjones1980 Posted April 2, 2018 Author Share Posted April 2, 2018 How do I assign stomps to loop Quote Link to comment Share on other sites More sharing options...
codamedia Posted April 3, 2018 Share Posted April 3, 2018 21 hours ago, jeffjones1980 said: How do I assign stomps to loop I don't know if I understand your question.... can you elaborate on what you want to accomplish. Quote Link to comment Share on other sites More sharing options...
jeffjones1980 Posted April 3, 2018 Author Share Posted April 3, 2018 So I am sending signal to the front of the amp via the effects send on the Hx but how do I set up the hx loop to have effects before it ie drives Quote Link to comment Share on other sites More sharing options...
EdwinV Posted April 4, 2018 Share Posted April 4, 2018 On 2-4-2018 at 2:57 AM, codamedia said: Guitar > HX Effects Input > Setup blocks of effects that normally go in front of an amp such as comps, overdrives, etc.... Insert an LOOP Block in the HX Effects > Send that loop out to the input of your amp Effects Send from your amp to the RETURN of the loop in on the HX Effects > Setup blocks of effects that normally go in the loop of an amp such as delays, reverbs, etc... Output of the HX Effects into the effects loop RETURN on your amp. Doing that will limit your HX Effects to 8 effects, and 1 Loop Block... (9 blocks total) Hope that is what you are after. In your HX signal path, the blocks that are before (left from) the FX LOOP block are in front of your amp; the blocks after (right from) the FX LOOP block are in your amp’s effects loop. Quote Link to comment Share on other sites More sharing options...
