midway Posted April 17, 2018 Share Posted April 17, 2018 Hi there, actually I have my Pod HD500X mounted into a kind of mixer case ~ 80cm x 45 cm, the receiver of my relay lays beside the pod, power supply behind the Pod. I am using this already for a long time as transmitter: https://www.session.de/LINE-6-XD-V35-L.html?gclid=EAIaIQobChMIiZ2whIXB2gIVA6oYCh1TLARfEAQYDyABEgKy8vD_BwE I´d like to have a smaller board. --> I am thinkin about mounting my pod hd 500x on a pedaltrain 60x40 cm (or similar from palmer). my question is, if I mount the receiver XD-V35 beneath the pedaltrain , and that means also for the receiver to be consealed a little bit under the pod, will this have an effect on the receiving quality? I hope you understand my question in my bad english:-) Have a nice day! Regards Rüdi Quote Link to comment Share on other sites More sharing options...
ADBrown Posted April 19, 2018 Share Posted April 19, 2018 Hi Rüdi, mounting your XD-V35 beneath your pedal train, and being partially blocked by the POD could lead to reduced signal strength; which could lead to reduced range and dropouts. Typically you do not want any metal barriers between your transmitter and receiver. Quote Link to comment Share on other sites More sharing options...
