pipelineaudio1 Posted May 3, 2018 Share Posted May 3, 2018 Is there a way to switch the wah on and off by moving the pedal the way TH3, Axe FX, Tonestack and some of the others do it? I read that this may have been added to the Helix and theres a way to trick the HD500X into doing it by assigning to the mix control as well as the wah, but can the Firehawk do it? If not, how hard and how reliable is the wah switch on firehawk? The XT Live takes too much pressure, and a lot of the other softswitch style ones are too unreliable, too easy to switch off, etc... Quote Link to comment Share on other sites More sharing options...
robertgoddard Posted May 3, 2018 Share Posted May 3, 2018 The wah switch on my Firehawk is pretty easy to engage and reliable. You can't be heavy footed for the reasons of softswitch styles you mentioned. You could also set up 2 identical patches with the wah on and wah off, so you would have definite engagement, but you'd have a 50-100ms delay when switching patches. Could be even shorter since it's the same patch, just one parameter change. Quote Link to comment Share on other sites More sharing options...
