pipelineaudio1 Posted May 4, 2018 Share Posted May 4, 2018 There's definitely some good tone to be had in here! In Blue, Firehawk's V30 cab. In Red, Celestion's own V30 impulse If only we could chose where in the chain the cab goes Quote Link to comment Share on other sites More sharing options...
robertgoddard Posted May 4, 2018 Share Posted May 4, 2018 What do you mean placing the cab elsewhere? You can move every effect in front of the amp. You just can't simulate an effects loop between the amp/cabinet. Quote Link to comment Share on other sites More sharing options...
robertgoddard Posted May 4, 2018 Share Posted May 4, 2018 If you gave a detailed description of what you were trying to do, it would be more helpful. Quote Link to comment Share on other sites More sharing options...
pipelineaudio1 Posted May 4, 2018 Author Share Posted May 4, 2018 In the helix for instance you can run an Ir...so you could put the fx loop after the amp, which would allow you to send to a regular guitar amp for stage monitoring, while having a speaker Ir on the main outs....things like harmonizer go way better before the speaker but after the amp i figured out sort of ok workarounds mainly I was just surprised by how good the v30 cabinet was! I had read all sorts of doom and gloom posts about how the firehawk cabs sucked, but when I went to actually measure them, they were pretty spot on Quote Link to comment Share on other sites More sharing options...
