Native with pod HD
arislaf
From the manual:
Inputs & Recording Page
The Line 6 Audio MIDI Devices - Inputs & Recording tab
9 Record Sends List: Displayed here are the Record Sends for the current Line 6
device that will be available to your audio software. For POD HD Pro X you’ll see the
one, stereo “1-2 Main Out” Record Send.
10 Hardware Monitor Level: This slider independently controls the volume of your
processed Source Input tone output for monitoring (the signal fed to the device’s main
outputs). It does not affect the level of the signal fed to your computer via the Record
Send. This allows you to balance your guitar’s monitor level against the playback audio
from your computer, such as when recording in DAW software.
Your DAW software may also offer its own “software monitoring” function. You may want to use
the DAW’s software monitoring in some scenarios, such as if you want to hear your guitar signal
processed with plug-ins on the DAW track. When utilizing DAW software monitoring, you’ll want
to set this Hardware Monitor slider to minimum to allow you to hear only the DAW software
monitoring signal.
