koeno100 Posted May 11, 2018 Share Posted May 11, 2018 I bought a second hand Line 6 M5 a while ago and I noticed that the position of the pots don't match the absolute value it should give. For example, when I'm using the Pitch Glide, when I turn the pitch knob all the way down, it gives me -24.0 as value, but when I turn it all the way up, it gives 23.5 as max value, and I can't get beyond that value. I discovered the factory test mode and played a bit around with this, and apparently all my potmeters do turn all the way down 0% (shows a 1 because succesful), but none of them turns to 100% (See attachment, all the pots show a 0 as right digit). Is there any way I can calibrate my pots? I've done multiple factory resets but they don't seem to help. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 11, 2018 Share Posted May 11, 2018 "Is there any way I can calibrate my pots?"--- No. It will need to be taken in for servicing. Log a support ticket and the will get things going. Quote Link to comment Share on other sites More sharing options...
