Tuliololo Posted May 18, 2018 Share Posted May 18, 2018 Hi guys, i have some troubles with my setup. I used to monitor my sound on liveshows via "phone" output. I made a preset with amp and cab emulation, sent it with XLR's to mixing console, so phone output gave me the same sound as the soundguy gets. But recently i got an amp, so i tried to do more complicated thing: i made a patch with effects for amp and panned it Right and connected Pod with real amp with 1/4 jack from right output, and put amp and cab emulation on the Left, so i could hear left channel in left headphone. But something went wrong and i can hear both left and right channels in real amp and it ruins the whole idea. Maybe someone can tell me, what i done wrong? Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 18, 2018 Share Posted May 18, 2018 6 hours ago, hurghanico said: solution: plug a dummy jack into the other unused 1/4" jack output, and you'll get again the separation of the 2 channels, and just 1 channel in each output ^^^^ THIS ^^^^ My setup is very similar and the dummy plug in the unused 1/4" output solves the problem. Quote Link to comment Share on other sites More sharing options...
stormstudios Posted May 18, 2018 Share Posted May 18, 2018 I can also confirm this works for what you want to do. Dummy adaptor plug for the win. Quote Link to comment Share on other sites More sharing options...
Tuliololo Posted May 20, 2018 Author Share Posted May 20, 2018 On 5/18/2018 at 5:59 PM, hurghanico said: when you plug just one jack cable to one of the two 1/4" jack outputs, both 2 channels L and R are mixed down into a mono signal (the XLRs are not affected), ie you loose the stereo separation, and the signals of both channels go through the same jack output.. solution: plug a dummy jack into the other unused 1/4" jack output, and you'll get again the separation of the 2 channels, and just 1 channel in each output _____________________________________________________________________________________________________________________________________________________ All about POD HD500/X new forum Huge thanks man, this works perfect! 1 Quote Link to comment Share on other sites More sharing options...
