ke3ee Posted October 22, 2013 Share Posted October 22, 2013 Can you blend Mag and Piezo on lets say positions 2 and 4 of the JTV69? Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 22, 2013 Share Posted October 22, 2013 Yes... There's a couple of ways you can do it now with the 2.0 firmware and Workbench HD. If you want to save a blended model on the guitar itself, you can add the signal from the magnetic pickups into the model. With this method, though, you're still left with a blended signal coming out of the guitar. The other thing you can do is set up a dual tone in the HD500 and have the input for one be the Variax model and for the other one be the magnetics. With this, you could blend the two signal per your preference in real time. Quote Link to comment Share on other sites More sharing options...
GearFarm Posted October 22, 2013 Share Posted October 22, 2013 Yes. Page 10 of the Workbench manual. Magnetics BlendUse the Magnetics Blend control to blend in the magnetic pickups on your JTV guitar with your model.Magnetics Blend Preset Volume 0.0 dB ModelOur magnetic pickups are hardwired to the 5-way/3-way switch in your Variax, so whatever pickups you haveselected on your guitar will get blended in here. You could select an Acoustic 12 String model, for example,and mix in your magnetic pickups for a rich electric/acoustic blend.Note: The magnetic pickups on your Variax are not alt tuned by the Variax DSP, so best results can beobtained by blending your magnetics with standard or harmonically compatible tunings only Quote Link to comment Share on other sites More sharing options...
