lumper Posted June 19, 2018 Share Posted June 19, 2018 I bought the Spider V 240hc in February it came with Steinberg le or something, I went today to try and set it up for the first time, it needs an activation code. Where do I get this code? Thanks for any help. Matt 1 Quote Link to comment Share on other sites More sharing options...
SeaRefractor Posted September 18, 2018 Share Posted September 18, 2018 Have you registered your amp? If so, go to your Line 6 account and select "Purchase History" under Hardware & Software. You should see a line saying "Cubase LE" under items with a "details" link. You'll be provided a download access code to use at MySteinberg. Click on "Create account" if you don't already have one and then provide the download code in the "Register eLicenser / Sofware & Enter Download Access Code" field. You'll then unlock and receive a separate "activation code" from Steinberg to use. If you haven't registered your amp, do that soon. Quote Link to comment Share on other sites More sharing options...
Spiderneuwied Posted October 5, 2018 Share Posted October 5, 2018 When registering the Spider V30 you should get the cube base for free. Or have I misunderstood something? Because I have not received a cube base until today. Quote Link to comment Share on other sites More sharing options...
Spiderneuwied Posted October 5, 2018 Share Posted October 5, 2018 On 9/19/2018 at 12:14 AM, SeaRefractor said: Have you registered your amp? If so, go to your Line 6 account and select "Purchase History" under Hardware & Software. You should see a line saying "Cubase LE" under items with a "details" link. You'll be provided a download access code to use at MySteinberg. Click on "Create account" if you don't already have one and then provide the download code in the "Register eLicenser / Sofware & Enter Download Access Code" field. You'll then unlock and receive a separate "activation code" from Steinberg to use. If you haven't registered your amp, do that soon. Thanks for help Quote Link to comment Share on other sites More sharing options...
Spiderneuwied Posted October 5, 2018 Share Posted October 5, 2018 Thanks for help Quote Link to comment Share on other sites More sharing options...
