I've got FBV3 and Spider V 240
FBV 3 controls are pretty set, aside from moving effects around, there isn't much assignable. The up and down arrow foot-switches let you switch between banks of presets, foot-switches A-D let you access the 4 presets in that bank. FS1-5 control your effects. FS 1 & 5 will always be locked to your compressor and reverb. FS 2,3,4 are all assigned to whichever 3 effects are in the preset (modulation, delay, distortion, etc). The function button lets you control the looper. The expression pedal does have a toe tap feature meaning you can toggle between wah and volume pedal; indicated by the two lights near the heel. You can also assign an effect parameter (ex:Delay mix) to the expression pedal in place of wah.
  • 11 months later...
