csj5150 Posted July 27, 2018 Share Posted July 27, 2018 I have scenes set up but also like to use my M13 in stomp box mode for other songs that I don’t need a scene. I have it in latch mode. Example: in stomp box mode in bank 3, lower switch I have an overdrive. Then I tap scene and pull up my Edge setting, I get my 2 delays, Octo, & vetta Comp. Works great then if I tap scene again to return to stomp box mode, I see those 4 Edge settings but I I phish the button that I had the OVerdrive, its something completely different. I want to have my 12 stompboxes set, then flip into a scene, then go back to my 12 stompboxes where they were prior to activating the scene mode. Make sense? Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 27, 2018 Share Posted July 27, 2018 It sounds like you're changing scenes when you're in Scene Mode, and then when you go back into Stomp Mode, you simply have different effects set up in that scene than you did the first one. Each scene is a different layout of 12 effects, so if you want to have the same stomp setup in each scene, you just need to change the effects in each scene to be what you want them. Quote Link to comment Share on other sites More sharing options...
csj5150 Posted July 27, 2018 Author Share Posted July 27, 2018 Ok I understand. Certain scenes have effects that I wouldn’t normally have in my 12 stomps. So what you are saying is in stompboxes mode I can only have stomps that would be included in those particular scenes? In essence, the are not truly indepenent modes? Quote Link to comment Share on other sites More sharing options...
csj5150 Posted July 27, 2018 Author Share Posted July 27, 2018 so, i discovered that when you create a scene, everything on your board is 'saved'. the items selected for the scene are saved as the scene but all of the other stomp boxes that are on your are hidden. I created a "home" scene. started with the 12 stomp boxes that I wanted then made the scene 4 of them. and just turn off and on the ones I want to use at a particular time. In essence, the stomp box mode and scene mode can't work together. Its one or the other, so looks like I'll be in scene mode all of the time. Quote Link to comment Share on other sites More sharing options...
