HELP!!!!
stargazerhei
You have run out of memory. There is a solution. Take your output for path 1 and assign it to path 2a (I think. I'm not home). now move some of your effects to path 2 which has the same amount of memory as path 1. Then assign path 2's output to what path 1's output is assigned to now. Should have enough memory for that now. Path 1 is the top line, Path 2 is the bottom line.
thx man !!!! i think i am start getting understand!!   thx for the help
Each path (1 and 2) runs off it's own processor, so you have to get creative sometimes on splitting up the items in your signal path between the two. Generally I have the amp on path 1 and the cabs/IRs in path 2. Those are the biggest DSP hogs.
