Zuzzu Posted October 27, 2013 Share Posted October 27, 2013 Hi there, I have aways use my HD throught a PA and a keybooard amplifier as monitor. I'd like to run it throuht a FLEXY II with the 4cm plus Midi. Everything is running pretty fine (need to work a bit but seems to have a good and luod sound) except for the MIDI commands. The channels on Flexy are changed directly by the preset footswitches on the HD in this way: FS5>chD, FS6>chA, FS7>chB, FS8>chC. No other changes will be keept no matter how many commands I'll send to it. Please tell me where I make it wrong, or if simply the two devices are not compatibles... Thanks for the help! Quote Link to comment Share on other sites More sharing options...
radatats Posted October 28, 2013 Share Posted October 28, 2013 Just a thought, but why are you using the amp modelling in the Flextone? I have one too and just run the POD output in stereo to the Flextone FX return with a stereo plug adapter. Works great and I can just use all the patches I made for the POD with out fiddling with MIDI settings... (you may have to put a dummy jack in the Flextone input too) Quote Link to comment Share on other sites More sharing options...
Zuzzu Posted October 28, 2013 Author Share Posted October 28, 2013 In fact is similar the way I run it (I use the 4 cables). But I've found that for some Patches maybe it could be easy to use the Flexy models. The only important thing is that I don't know if is my fault in program set up or if there's something wrong in those devices. And the Flaxy has still a GREAT sound! Quote Link to comment Share on other sites More sharing options...
