HX Effects - global EQ?
joeriz
4 hours ago, soundog said:
Nope. You would need to create an EQ block, and then copy/paste it to your presets.
Understood. Much appreciated...thank you.
So then if I make changes to the setting of my EQ  block they will carry over to any presets which include it?
Another no... you need to create that block and set it accordingly on each patch.
You could throw an EQ pedal in one of the loops and just insert that loop where ever you want the EQ... then it would be global, if inserted.
Keep in mind, the HX Effects is marketed to those using guitar amps... when used like that the global EQ is ultimately the amp itself.
....also, if you created (for example) an EQ block you really like, its fairly quick easy to copy and paste it between multiple presets when using the editor software. Maybe in the future they'll add the ability to paste to multiple presets?
