JakeMann35 Posted September 1, 2018 Share Posted September 1, 2018 Hi All I'm having issues with the 7 cable method. I believe everything is wired as it should be. But when both amps are on, one seems to control the volume of the second. The second is very quiet and very noisy. Anyone know how to resolve it Quote Link to comment Share on other sites More sharing options...
JakeMann35 Posted September 1, 2018 Author Share Posted September 1, 2018 Ah... just needed a stereo fx send and return... Not mono! Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted September 2, 2018 Share Posted September 2, 2018 4 Cable Method (4CM) Cable #1 Guitar to Helix/HX Effects Guitar In Cable #2 Helix/HX Effects FX Send Loop 1 to Amp #1 Main Input Cable #3 Amp #1 FX Send Loop to Helix/HX Effects FX Return Loop 1 Cable #4 Helix/HX Effects 1/4" Left (mono) Out to Amp #1 FX Return Loop 7 Cable Method (7CM) Cable #5 Helix/HX Effects FX Send Loop 2 to Amp #2 Main Input Cable #6 Amp #2 FX Send Loop to Helix/HX Effects FX Return Loop 2 Cable #7 Helix/HX Effects 1/4" Right Out to Amp #2 FX Return Loop Quote Link to comment Share on other sites More sharing options...
dcm_guitar Posted September 5, 2018 Share Posted September 5, 2018 I've been trying for two days to get this sorted and I've had nothing work. Until now (FINALLY!)........ The above helped. I have a couple of questions. I could NOT figure out how to change the FX loop from mono to stereo using the controls on the HX effects. I had to download the HX Edit App. Changing the FX Loop to stereo in this editor is easy. How do you change the FX block to stereo on the device? The only way I can get the 7CM method to work while keeping the signal to amp#2 into the inout (and not directly to the power amp section of amp#2) is to put the stereo FX block as the last block in the signal path. Is this what everyone else is experiencing? Quote Link to comment Share on other sites More sharing options...
