RonSom1976 Posted September 2, 2018 Share Posted September 2, 2018 Hello, got the experience: My POD HD 500 is "losing" parts of the to load sound - but only from time to time. Example: preset does load - but without the delay Example: preset does load - but only one of the dual amps I need to restart the POD - then it works again (not fine while a gig). Any ideas ...? Thanks! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 4, 2018 Share Posted September 4, 2018 Assuming you are: 1. saving your patches correctly 2. not using the usb/edit when it is not needed then you could try: 1. install/reinstall latest firmware 2. global reset 3. use a different power supply Quote Link to comment Share on other sites More sharing options...
RonSom1976 Posted September 4, 2018 Author Share Posted September 4, 2018 Hi, thanks for the answer. How do I do a global reset - the "press left arrow while switching to power" seems not to do anything Quote Link to comment Share on other sites More sharing options...
Anthony951306 Posted September 4, 2018 Share Posted September 4, 2018 Hello, my HD 500 fails to connect to the PC, the HD Edit pod works properly, but when you open any Daw gives me a screenshot and restart the PC. Possibly it is a failure of drivers, but I have already updated, uninstalled and reinstalled and follows the same error. My operating system is Windows 10. I hope you can help me, greetings and thank you. Quote Link to comment Share on other sites More sharing options...
aquilagrativol11 Posted September 9, 2018 Share Posted September 9, 2018 Hello good afternoon I'm having problems with my POD HD 500 I put the volume sound of the amp selected on the pedalboard at 100% volume and suddenly it is at 7% or 0%. Example amp fender tweed: drive 50% Bass 53% Mid 45% Treble 72% Pres 55 CH VOL 100% saved.When the CH VOL is set to 0% or 7% I would like help solving the problem Thank you Quote Link to comment Share on other sites More sharing options...
