USB problems that cause dirty sounds
How long is your MIDI cable? MIDI cables longer than 20 ft need to be of a higher quality than just a standard MIDI cable.
You may also need to adjust the buffer settings in the ASIO control panel. If you have it too small, it won't be able to keep up you'll get strange noises. 256 samples is a good place to start. Make sure you're using the ASIO drive and not MME or WDM.
