ElectricRelig Posted September 16, 2018 Share Posted September 16, 2018 Hi everyone, I recently purchased an Alesis SampleRack from a local store, only because it was really the only option that even came close, in my city, to potentially letting me do what I need. What I Need: 1) A unit that holds my samples. 2) A unit to allow me to trigger those samples via MIDI, thus being triggered by my Helix 3) The information on how to use these two pieces together to get my samples to come out of a speaker. I've tried everything I can think of in terms of connections; I've tried diving deep into the Command Centre but couldn't figure out a way to even trigger the on-board sounds of the SampleRack. I am looking for some Helix wizards, or MIDI gurus! Thank you, Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 16, 2018 Share Posted September 16, 2018 I had a quick look at the User Guide for the Sample Rack. I can't imagine why you'd want to try to play this thing with your Helix. WRONG tool for the job. That said: In Helix Global/MIDI, note the Helix Base Channel Number. Turn MIDI PC Send/Receive OFF. Using a 5 pin MIDI cable, connect the Helix OUT to the SR IN. On the Sample rack, make sure that the MIDI Receive Channel matches the Helix Base Channel. Select a Kit. You MIGHT be able to send a PC# using an Instant Command (see below). Go to the MIDI area and see which MIDI Notes the TRIGGERS use to trigger what sounds in the kit. In Helix Command Center, set the buttons correspondingly. The User Guide that I found at the Alesis website gives virtually NO info about using Sample Rack with MIDI, other than a picture of a MIDI controller with drum pads connected to it. There's no info about whether or not you can change kits via MIDI (though it seems to imply that you can - start by sending PC# 001 to [MAX # of kits]), and since there's no default MIDI Note map, which appears to imply that Alesis thinks that all MIDI drum pad controllers use the same layout, which seems absurd. By looking in the MIDI area to see what notes the triggers send by default, you may be able to figure it out. Good Luck! Right tool for the job? Maybe one of those pedal rigs that keyboard players use with synths? Looks like the pedals on a Hammond Organ. Probably costs a small fortune. EDIT - using a VST Synth/Sampler with a computer would be pretty easy to set up. Took me a few seconds when I tested it. Quote Link to comment Share on other sites More sharing options...
ElectricRelig Posted September 16, 2018 Author Share Posted September 16, 2018 13 hours ago, rd2rk said: I had a quick look at the User Guide for the Sample Rack. I can't imagine why you'd want to try to play this thing with your Helix. WRONG tool for the job. That said: In Helix Global/MIDI, note the Helix Base Channel Number. Turn MIDI PC Send/Receive OFF. Using a 5 pin MIDI cable, connect the Helix OUT to the SR IN. On the Sample rack, make sure that the MIDI Receive Channel matches the Helix Base Channel. Select a Kit. You MIGHT be able to send a PC# using an Instant Command (see below). Go to the MIDI area and see which MIDI Notes the TRIGGERS use to trigger what sounds in the kit. In Helix Command Center, set the buttons correspondingly. The User Guide that I found at the Alesis website gives virtually NO info about using Sample Rack with MIDI, other than a picture of a MIDI controller with drum pads connected to it. There's no info about whether or not you can change kits via MIDI (though it seems to imply that you can - start by sending PC# 001 to [MAX # of kits]), and since there's no default MIDI Note map, which appears to imply that Alesis thinks that all MIDI drum pad controllers use the same layout, which seems absurd. By looking in the MIDI area to see what notes the triggers send by default, you may be able to figure it out. Good Luck! Right tool for the job? Maybe one of those pedal rigs that keyboard players use with synths? Looks like the pedals on a Hammond Organ. Probably costs a small fortune. EDIT - using a VST Synth/Sampler with a computer would be pretty easy to set up. Took me a few seconds when I tested it. That was quite helpful, I managed to get the Alesis to play the built-in sounds using my Helix. I also was able to find a way to change kits on the fly. Now my next task is to load an SD card up with my backing tracks and see if I can figure out how to organize it so I can use it as a player for live shows. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 17, 2018 Share Posted September 17, 2018 3 hours ago, ElectricRelig said: That was quite helpful, I managed to get the Alesis to play the built-in sounds using my Helix. I also was able to find a way to change kits on the fly. Now my next task is to load an SD card up with my backing tracks and see if I can figure out how to organize it so I can use it as a player for live shows. Glad I could help. You're on your own with the SD card. That's got to be one of the most pathetic User Guides I've ever seen. GOOD LUCK! Quote Link to comment Share on other sites More sharing options...
