Bear706 Posted September 23, 2018 Share Posted September 23, 2018 Using the Helix Rack and floor controller. I use the Preset Mode, since I use a preset for more than one song. I'm using the Ernie Ball VP Jr. for an expression pedal. Works great, except, if I back the volume off using the pedal, then switch presets going to the next song, the volume on the new preset is full blast, until I rock the pedal back and forth. Is there a setting I'm missing, or a bug? Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted September 23, 2018 Share Posted September 23, 2018 The state of the volume pedal is stored whenever the preset is saved just as is any effect state of off and on. If you want the volume pedal to be in the heel position, place it in the heel position and save the preset. However remember when the preset is recalled the state will be zero even if the pedal is full on. Quote Link to comment Share on other sites More sharing options...
Bear706 Posted September 23, 2018 Author Share Posted September 23, 2018 Interesting... doesn't help what I'm trying to do much.. but it does explain a couple of things.. Thanks for the reply... Quote Link to comment Share on other sites More sharing options...
mfalkler Posted September 23, 2018 Share Posted September 23, 2018 In the global settings, there are options for each expression pedal to save the state per preset, per snapshot, or globally. Setting to global should do what you want Quote Link to comment Share on other sites More sharing options...
