soundog Posted October 16, 2018 Share Posted October 16, 2018 The manual says to change an FX block, you need to be in Stomp mode, select the foot switch for the block you want to change, then use the Big Knob to change it. All well and good, but what if.... I have a number of presets for which I "de-assigned" its foot switch. I do this to cut down on the number of lit buttons for certain blocks that I like to leave on (eq, compression, etc), or sometimes I have several blocks assigned to a single foot switch. In that case, how do I use (without using HX Edit) change a block if it has no single foot switch assigned to it? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 16, 2018 Share Posted October 16, 2018 Select the block. Press MENU. Press BYPASS ASSIGN. Press ACTION. Press CLEAR ASSIGNMENTS. SAVE. Quote Link to comment Share on other sites More sharing options...
