Spider Valve 112 MK1 Circuit Diagram Question
akalchschmid
Hi all,
I have a question regarding the circuit diagram of the Spider Valve 112 MK1 (I attached a screenshot from the manual).
As I read it, the “All-tube power amp” section consists of the pre-amp tubes AND the power amp tubes. However, the “Preamp out” is right before that section where the pre-amp tubes are. And the input to this  “All-Tube Power Amp” section is labelled “Power Amp In”.
So, when I go with an external signal (in this case from Hx Stomp pedal) into the “Power Amp In”, I still use the preamp and poweramp section of the Spider Valve, correct? Although the section from “Guitar in” to “Preamp Out” is completely bypassed.
I’m confused…
The buffer stage before the pre-outs are also pre-amps.
The tube power stage has pre's as well. You don't go high gain all at once, so there are two pre-amp tubes.
Typical in such a configuration. It's a hybrid amp, pre stage out of the processor board, a pre stage for the
input of the tube amp section.
