sinlimo Posted December 18, 2018 Share Posted December 18, 2018 When in stomp mode, is there any way to assign a block to that third button (which is currently the tap/tuner button)? I'd like to run with a distortion block, chorus block, and looper block in stomp mode, but unless I can re-assign that third button, it ain't happening. Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted December 18, 2018 Share Posted December 18, 2018 Yes you can. In the global settings you can choose to have the FS3 run as a regular stomp option instead of the tap/tuner option. Quote Link to comment Share on other sites More sharing options...
sinlimo Posted December 18, 2018 Author Share Posted December 18, 2018 awesome, thank you! I'll give that a shot tonight. If I do that, then how can I access the tuner? Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted December 18, 2018 Share Posted December 18, 2018 It's kind of an instinctual reaction for me at this point, but if I remember right you press the "action" and "page" button simultaneously. Not quite as easy as tapping a button, but it works in most applications. 1 Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 19, 2018 Share Posted December 19, 2018 20 hours ago, sinlimo said: awesome, thank you! I'll give that a shot tonight. If I do that, then how can I access the tuner? You can use the Action and Page > buttons as indicated above, or you can assign the tap/tuner function to FS4 or FS5 in the Global Settings menu. You can also access the tuner via MIDI if you want. Quote Link to comment Share on other sites More sharing options...
