jamcoops Posted December 22, 2018 Share Posted December 22, 2018 Hi all, I'm running a wet dry set up. the Wet amp is a Bluguitar AMP1 and the dry is a Powerstage SD170 using two Victory Preamps (Kraken and Countess). Now, for some reason the Kraken has an inverted polarity on the crunch channel (really annoying!!!! but not the HX's fault). Therefore, I need to tell the HX mixer to change this setting when I change Snapshots. My issue is that it will not save the command, nor it seems any other command in the mixer. I've tried assigning to a foot switch but that will not save its setting either per snapshot. Am I being thick or is there a bug here? Oh, and does anyone know if Line 6 are likely to come out with a fix for the instant commands working the ExtAmp switching? Really annoying using four of my switches up. Many thanks, Mark Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 22, 2018 Share Posted December 22, 2018 You need to treat those parameters like any other parameters you want change with snapshots - they need to be assigned to snapshot controllers. Push and turn the knob under the parameter on the unit itself to do that, or in HX Edit, simply right click on the parameter value and select Snapshot from the pulldown menu. Quote Link to comment Share on other sites More sharing options...
jamcoops Posted December 22, 2018 Author Share Posted December 22, 2018 Hi Phil, Thanks for that. Stupidly I hadn't tried it direct on the unit, which actually works as it should. It still doesn't work when using HX Edit to assign in the first instance, but, I am happy now. Thanks for the quick response. Mark Quote Link to comment Share on other sites More sharing options...
