thomasmirus Posted December 23, 2018 Share Posted December 23, 2018 Maybe there is already a solution. However, when I install Native on a Mac I do see the files in the components and vst3 folders in library/audio/plug-ins. But I don't find it in the vst or vst/line6 folder. Any ideas out there how to fix it? Thanks! Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 23, 2018 Share Posted December 23, 2018 2 hours ago, thomasmirus said: Maybe there is already a solution. However, when I install Native on a Mac I do see the files in the components and vst3 folders in library/audio/plug-ins. But I don't find it in the vst or vst/line6 folder. Any ideas out there how to fix it? Thanks! Hi Thomas, This seems a little bit strange because you state that you have managed to install the AU version into the components folder and successfully installed VST3 version of Helix Native. As you already know Native is a plug-in not a stand alone application, so you should find it in one of these two places on your Mac: ~/Library/Audio/Plug-Ins/VST (the ~ represents your home directory) Or here /Library/Audio/Plug-Ins/VST Those are the only two places that the software is installed so I really don’t understand why you cannot find the VST2 plugin. If everything is installed correctly it should just show up in your DAW as a regular VST plug in under effects. Hope this makes sense. Edit: Read This: Quote Link to comment Share on other sites More sharing options...
radfordsmith Posted February 7, 2019 Share Posted February 7, 2019 I'm having the same issue. I checked both locations above for the VST2 plugin and nothing, whereas the VST3 and AU plugins are installed in the expected location. Not really a blocker for me, but this seems like a bug in the installer rather than a user error. Quote Link to comment Share on other sites More sharing options...
nepenthez Posted April 16, 2019 Share Posted April 16, 2019 Found the fix for this - when installing Helix Native, on the prompt after you agree to the licensing, when the installer asks where to save the files, there is a Customize button on the bottom. Click Customize and select VST2. Default settings when trying to install on a Mac had this option unselected. 1 1 Quote Link to comment Share on other sites More sharing options...
vne1558 Posted March 21, 2020 Share Posted March 21, 2020 Thanks so much man... I was tearing my hair out trying to get this to open in Reason 11! Quote Link to comment Share on other sites More sharing options...
