smrybacki Posted November 13, 2013 Share Posted November 13, 2013 Man, I didn't really think about the possibilities avaible with such a simple add on. Like having a volume swell and mix level on chorus readily available -- or a hundred other things I haven't even thought about yet. Gotta say that sometimes the simplest things can give you a big boost in creativity. Quote Link to comment Share on other sites More sharing options...
guitarno Posted November 13, 2013 Share Posted November 13, 2013 What EX pedal did you get? I am considering this for an add on at some point. I'm wondering which Ex pedal would be a good one as far as features vs price. It would be great to have a second one - I like to have one dedicated to volume. The built-in pedal is OK but it sure is a bear to switch from a sitting position. Also I'm not sure I like the feel of it - doesn't seem to have enough resistance for me - too easy to go too far too fast. I should probably try to adjust it a little. Maybe I can tighten up the travel and change the sensitivity of the toe switch. Quote Link to comment Share on other sites More sharing options...
smrybacki Posted November 14, 2013 Author Share Posted November 14, 2013 What EX pedal did you get? I am considering this for an add on at some point. I'm wondering which Ex pedal would be a good one as far as features vs price. It would be great to have a second one - I like to have one dedicated to volume. The built-in pedal is OK but it sure is a bear to switch from a sitting position. Also I'm not sure I like the feel of it - doesn't seem to have enough resistance for me - too easy to go too far too fast. I should probably try to adjust it a little. Maybe I can tighten up the travel and change the sensitivity of the toe switch. I got the Line6 EX1 pedal for $49.99 from Sweetwater 9also available elsewhere I'm sure). I also considered the Mission Engineering pedal that goes for $129.99. The Mission pedal is by all accounts sturdier and heavier, much like a Dunlop Crybaby Wah. I opted for the EX1 because my situation is an at home guitar experimenter and I don't need mil spec stuff for that. I also found a few folks who claimed to gig regularly who said it was fine and had lasted them a few years in that kind of use. I can tell you that I had the same problem you describe here, namely it is difficult to switch pedals from EXP-1 to EXP-2 via that stiff toe switch, and I figured for $50, I could have both available at once. So far, so good and although this one is made primarily of plastic, it seems sturdy enough for my purposes. Hope that helps.... 1 Quote Link to comment Share on other sites More sharing options...
Inerzia Posted November 14, 2013 Share Posted November 14, 2013 I wasn't gigging with my EX1 that much when it broke... :DI just stomped on it a bit too hard. Maybe for the price you paid, a plastic pedal is OK, but I paid almost 80 euros for mine, and that changes radically the perception of the product's quality.Anyway, yes, adding a secondary pedal makes a huge difference if, like me, you're into real-time control. Quote Link to comment Share on other sites More sharing options...
wolbai Posted November 14, 2013 Share Posted November 14, 2013 I am gigging with the EX1 (approx. 20 gigs) - no problems, reliable so far. May be I am not jumping that much on stage ... Using expression pedals (the internal and additional one) can be indeed very creative. Looking at the pedals boards of pros, a lot of them have two and more pedals in their setup. Especially for gigging pedals can be very helpful to smooth/blend out two song parts more easily. The sky is the limit for creativity here. Over the time I have work out 2 applications which works for me: Apart of the Wah-function, my EXP-1 is mainly dedicated to the delay-mix parameter where I easily can add some delay to any Rhythm or Leadparts - even into extremes. Sometimes I also assign other effects like chorus to the EXP-1 or even two completely different POD-HD presets (2 amps, clean, distorted, etc.) I mainly use the EXP-2 to adapt the gain / distortion level (on same volume level) of my guitar sound: Tube comp-parameter, distortion pedal-paramter, amp-drive, amp-volume are the devices I am controlling with the EXP-2. It is a bit like the old school "volume knob"-control but more versatile to me. Quote Link to comment Share on other sites More sharing options...
smrybacki Posted November 14, 2013 Author Share Posted November 14, 2013 I like having a volume pedal at all times for sure...after that, the mind is the limit! Quote Link to comment Share on other sites More sharing options...
