josephyballew Posted January 10, 2019 Share Posted January 10, 2019 I set my whammy up to do the song by Audioslave Like a Stone. It is a very simple setting. Heal is your guitar octive and toe is one octave above. When I go to the heal position to remain in the guitar octive the sound disappears. I can move the pedal up slightly at +1, but the sound disappears at 0 heal position. This is in the programming of the unit. I am surprised no one has caught this yet. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted January 10, 2019 Share Posted January 10, 2019 As in the whammy turns off, or as in you're at unison pitch so it doesn't sound like there's any effect? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 10, 2019 Share Posted January 10, 2019 Works as expected. Have you got the exp pedal assigned to some other volume function? Quote Link to comment Share on other sites More sharing options...
josephyballew Posted January 10, 2019 Author Share Posted January 10, 2019 When I am in the unison position there is no sound at all Quote Link to comment Share on other sites More sharing options...
josephyballew Posted January 10, 2019 Author Share Posted January 10, 2019 Using the Helix expression and has no other function except whammy on that preset Quote Link to comment Share on other sites More sharing options...
josephyballew Posted January 10, 2019 Author Share Posted January 10, 2019 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 10, 2019 Share Posted January 10, 2019 On 1/10/2019 at 2:22 PM, josephyballew said: Using the Helix expression and has no other function except whammy on that preset I'm attaching the test preset I used. Whammy is assigned to Exp Pedal1. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted January 10, 2019 Share Posted January 10, 2019 Make sure you don't have the volume pedal and the Whammy assigned to the same EXP pedal, and make sure they are BOTH assigned to the toe switch, or whatever switch you are using to turn on/off the whammy. 1 Quote Link to comment Share on other sites More sharing options...
josephyballew Posted January 10, 2019 Author Share Posted January 10, 2019 At the heal position it should be unison or just guitar sound. Everything above 0 is fine. At 0, heal position the sound dissapears Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted January 10, 2019 Share Posted January 10, 2019 try the test patch, check you assignments. something is not set-up right. Quote Link to comment Share on other sites More sharing options...
josephyballew Posted January 10, 2019 Author Share Posted January 10, 2019 I was using expression pedal 2 and it was clashing with the volume pedal. I changed to expression pedal one for whammy and expression pedal 2 for Volume and all works as it should 1 1 Quote Link to comment Share on other sites More sharing options...
josephyballew Posted January 10, 2019 Author Share Posted January 10, 2019 Thanks Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted January 10, 2019 Share Posted January 10, 2019 1 minute ago, josephyballew said: I was using expression pedal 2 and it was clashing with the volume pedal. I changed to expression pedal one for whammy and expression pedal 2 for Volume and all works as it should I've done that a few times, pretty easy mistake to make. Glad you got it sorted out. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 10, 2019 Share Posted January 10, 2019 Rock On! Quote Link to comment Share on other sites More sharing options...
